2003 F150 Leaking ABS Modulator Valve
Old Oct 12, 2020 | 12:15 PM
Loren's Avatar
I have a leaking ABS modulator valve out of one of the diagnostic ports of the valve assembly. I am having a difficult time finding a modulator valve block assembly. I do know it is a Kelsey Hayes module so I am assuming this may have been built for different manufactures. I am wondering if any one knows if you can use an AC Delco part number 19121925 in place of the Ford modulator assembly 6L3Z-2C286-A. They appear to be identical except the adapters where the brake lines attach and the plug to the motor. I was curious if there was anyone that has tried this or can provide any insight before I try this.
Old Oct 12, 2020 | 02:58 PM
Plenty out there if you want to pay the price - this one is the cheapest I found:
https://www.tascaparts.com/oem-parts...tor-6l3z2c286a
Old Oct 13, 2020 | 08:40 AM
Fbird's Avatar
ouch....I'm sure by now there are rebuilders out there...i recall 6 yrs back the ford dealer wanted $1400 to replace the entire ABS PUMP and MODULE on our 2002 Windstar.."the module can't be replaced"... A year after they had replaced the module!!!...B.S. .... I sent it to myairbags.com for a rebuild ...took 3 days $100 ......but THAT was only the MODULE. (btw...lifetime warranty...still works perfect)
