issues with steering system
Old Dec 3, 2020 | 07:14 PM
2002lariat's Avatar
had a bad power steering fluid leak, was going through a gallon every few hours.
-drained the fluid
-replaced the pump
-filled with ATF
P.S. worked fine like normal
a few weeks later, no power steering unless the engine speed was higher than 1200 rpm.
out of ideas, thoughts?
2002 F-150 Lariat Fx4 4WD Supercrew 5.4L Triton 2V
Old Dec 7, 2020 | 01:57 AM
jimbo74's Avatar
5 Year Member
is it sporadic? did you bleed it out? how's the level now?
Old Dec 11, 2020 | 07:23 PM
JCR 56's Avatar
If it's got fluid sounds like the pump is bad.
