2000 f150 lean codes
I have a 2000 f150 with the 5.4. It has the P0171 and P0174 lean codes in it. Earlier it had a couple o2 codes as well. I had it to a local shop and they replaced the o2 sensors and put a MAF sensor in it. After 20 miles or so the lean codes came back but not the o2 codes. it doesn't run rough anymore but still has the lean codes. The freeze frame data for when the codes were set is RPM-1435 Load- 97.3% Coolant 194 St Ftrm1 8.6 Lt Ftrm1 25 St Ttrm 2 1.6 Lt Ftrm 2 25.
At idle the fuel trims are St 1 -1.6 to 0.8, Lt1 4.7-6.3, St2 -1to .8, and Lt2 4.7. what would be the next things to check and eliminate? thanks
I'm not an expert but, it looks like the fuel trim is okay at idle and I think this indicates that there is no vacuum leak. From the videos I watch I think if there is a vacuum leak, the fuel mix will be lean at idle and will be okay when the engine is revved. Maybe a real mechanic will chime in.
If you test it with a gauge, be sure to test it when the engine is demanding more fuel, ie, at speed and under load, if possible. A pressure check at idle is likely to not show up much.
I changed the fuel filter and hooked up my pressure guage. It has 24 psi at idle and gets as low as 18 when at highway speeds and I step on it. Looks like I need a fuel pump.
I think the MAF reading is way too high. I would expect less than 1 volt at 12mph. You can test it with a voltmeter: Part 1 -How to Test the Ford MAF Sensor (4.2L, 4.6L, 5.4L) (easyautodiagnostics.com)
You can plug the vacuum line going to the Purge Valve to close off the leak at the vacuum canister. Note: You may want to plug the other hose on the Purge Valve too in case the Purge Valve is stuck open.
