High fuel trims at idle and load
As the title says I am dealing with high fuel trims. At idle bank 1 sits at 25% and bank 2 sits at 21%
1500 rpm bank 1 sits at 21% and bank 2 sits at 20%
2500 rpm both banks sit at 18% and any higher they go back up.
does anyone have any clue as what could be causing this? Truck is 1998 F150 5.4 V8 Lariat.
//UPDATE// I have done a smoke test and couldnt find any bad lines. I did the carb cleaner method and had no surging. At this point I think it's a fuel issue.
it could be a dirty injector. Idk though I'll go and replace my fuel filter to start and check prices in injectors.
https://www.obd-codes.com/p0171
What is the fuel pressure?
P0171 is for bank 1. Are you receiving a similar code for bank 2? Read this if you haven't already.
If you're only getting the one side code, the problem is not likely the MAF, fuel filter or an air filter. Those are items likely to affect both sides. And since you haven't found any air leaks, i agree with the idea to test/check the injectors on the bad side. Make sure they are all working. There are some tutorials on line for how to test them.
Exhaust leaks before the upstream O2 can cause lean codes. Looks like both banks are affected, it's just bank 2 hasn't reached the threshold to trip a P0174 yet, so don't rule out a vacuum leak or leaky intake gaskets. Throw a couple bottles of Techron in the gas to clean the injectors.
