2003 Ford F-150 5.4L Rattling/Grindy noise at 2,000+ RPM
Hello,
I'm another noob to the threads so please don't kill me if there's already a similar thread. My truck has a slow oil leak that I haven't yet tracked down. I topped it off with some more oil until I had a weekend where I can try to figure out where the leak is. I noticed immediately after adding oil, the truck lost power while accelerating, and there's now a strange rattling noise that sounds like it's coming from around the intake manifold area. Originally I thought maybe I put too much oil in but that idea was unfounded as there was no evidence of froth before or after removing some of the oil. Even after removing said oil (its between min and max on the stick), the loss of power and tapping remains. I know I've now used three different words to describe the noise but I will post video of my truck, and two other people's trucks all making the same noise. Neither of the other videos seem to have reached a conclusion.
There's is no check engine light nor a code yet, so I have to guess where to start. I plan on trying removing the serpentine belt this weekend to make sure I'm not hearing the fan or one of the pulleys. I'm even thinking of going as far as removing the valve covers, which is something I have never attempted before. I was told by a friend to try looking for an obviously out of place rocker arm, etc. I also tried looking up information regarding the IMRC because another user with an 05 was having the same issue but I think those are 3V 5.4L engines. I cannot seem to find a single video with regards to IMRC and the 2V 5.4L engine, So I was wondering if it even has one and where would it be (you can see the noob coming out). I figured if there's a plastic gear in there turning and it's stripped that might also explain the noise at that RPM and above, and the loss of power if the runners are stuck. These are all, of course, my guesses as I have no real experience beyond changing my brakes, both front Hub and bearing units, and my spark plugs. I've never messed with anything in the manifold or under the valve covers. I'm not sure if a spark plug that came loose would make such a noise but I changed them out myself (first time) back in August or September of 2020 (I found the driver side to be extremely tedious).
With that being said here are the videos starting with my own:
Sorry if my responses are delayed, as I'm currently at work and plan on beginning breaking down the suspected areas starting shortly after I get home. I will keep checking the thread until then though. Thanks ahead of time for any ideas anyone may have.
The noise in the first video sounds like a problem with one of the accessories at the front of the engine - fan clutch, alternator, etc. Pull the serp belt and fire it up, see if the noise is still there.
Loss of power can be blocked cats, take it to a muffler shop to have them checked.
For the noise check around the ngine compartment, something could be loose. I had a motor lift bracket rttling on mine only to find out the bracket had broken from vibration fatigue.
As for the loss of power, run a vacuum gage test. It can tell you a lot about what's happening with your engine including if you have a blocked exhaust.
It's an easy diagnostic test that only takes minutes.
I've been using a different car for now but plan on trying to pull apart the exhaust near the y pipe to see if the back pressure is relieved. That way I can figure out if the rear cats are also bad or if the issue is closer to the muffler.
Long story short, nothing has been resolved, I've poured in the amount to replace 2 out of 4 cats, and a new hissing noise has emerged.
