Intake manifold/ crossover pipe
Old Dec 8, 2021 | 09:24 AM
justin6712's Avatar
I had a water leak where the crossover pipe is so I went to change the gaskets and found out my gaskets failed due to the intake Manifold being cracked I replaced the manifold and put new gaskets and all manifold gaskets, crossover gaskets, etc. when I crank it it will run for a little while bout 1-3 minutes then start sounding like it’s cammed out which isn’t normal for a STOCK 5.4 2valve then it slowly dies as idle jumps I canbonky assume vacuum lines but I’m honestly lost
Old Dec 8, 2021 | 10:26 AM
We are lost too if you don't identify what you are working on with a few more details. Need to know a bit more than it's a stock 5.4 2 valve. Year? Aluminum or plastic intake? OEM or aftermarket replacement?
Old Dec 8, 2021 | 10:31 AM
justin6712's Avatar
Details
Sorry bout lack of info 2002 F150 Super crew cab FX4 5.4 2 valve plastic intake OEM I believe got at oReilly’s
Old Dec 8, 2021 | 11:23 AM
Fbird's Avatar
you didn't buy an OEM intake at o'Rielly's...you may have bought a DORMAN. FYI you MUST use DORMAN gaskets on a DORMAN intake. The ONLY gaskets that work with the oem FORD intake are....FORD.
Old Dec 8, 2021 | 11:27 AM
justin6712's Avatar
Ok then it’s a Dorman it came with gaskets and hardaware around 187$ from oreillys
