Shifting hard into 2nd gear
99 F150 4.6 V8 with 265K miles, been shifting hard into second last 100,000 miles. Doesn't do it if I go easy on acceleration. I have read that this is usually a broken spring in the 1-2 accumulator. I'm due for a fluid change so I will be dropping the pan. How hard is it to do this repair while on the truck? I would need to drop the valve body to get to the spring. Just wondering if it is risky to do this repair from under the truck
That's what I was worried about, the check ***** falling out. The hard shift is not a huge deal, I generally accelerate easy off the line, but on those times when I don't it really slams into 2nd. That's got to be hard on the driveline. Maybe it's better to do a simple fluid change and call it good. I don't want to create a new problem by pulling the valve body while underneath the truck
The valve body does NOT have to be removed to replace the 1-2 accumulator springs. I changed them on my 95 Mark VIII Lincoln 4R70W years ago because I wanted it to shift a little quicker. You have to use a jack to push the accumulator in enough to remove the snap ring and then everything comes out. I thought I had a broken spring on my 02 truck because it was shifting hard but it was my mistake playing with the superchips programmer. I bought replacement springs and there were two upper springs instead of the one the Mark had because of the tendency of the upper spring to break I suspect. I don't know what year Ford went to two springs on the 4R70W.
