View Full Version : 1997 - 2003 F-150
- Needin' some lift!
- No Horn No Cruise Control Issue Shift Indicator / Trans Linkage Adjust
- Sputtering after bypassing heater core
- What on Earth is This Thing?
- AC Compressor/System help!!
- Exhaust
- How to Remove Mirror Caps ('97-'03)
- 1999 4.6L 4x4 XLT questions
- Question with PTM grille surround and bumper pad
- ID this hood?
- Update...new heads, tails, third brake light, and grill
- Finally did it..
- Lost Spare tire key
- Jlt ram air
- A/C control switch vacuum lines
- 2003 king ranch step bar cover
- 01' wiper delay
- 2000 ford f150 will not start with key
- Instrument Cluster Trim Panel Part Description
- Oops! Put diesel in f150
- Pats code
- 2003 F150 pats system
- Help with Headers
- I Need Inspiration ASAP
- fishsniper's upgrade thread
- lightbar mounting
- Water Leak around handle 2000 4x4 X Cab
- Need help finding Brake Pressure Switch for 97
- 93 F150 Manual transmission whine
- desperate help! SES light, and rough idle!``
- terrible acceleration, rough idle, and service engine soon :(
- SSDD: F150 windows
- 33x12.50r17
- 4.2 Engine Swap Question
- Got in a wreck
- Door Lock
- Cruise Button 2001 F150
- Supercab Full- Audio Build/Ideas
- Need a power source in the engine compartment for angel eyes
- Exhaust Routing Help!!!
- 171 and 174
- What lift kit?
- Supercharged 4.6
- 02 fog light wiring harness
- Low voltage issue? Check inside..
- squeaking noise
- The Goat's twin
- Everyone show off your 2wd trucks here
- mtr014's Modification Thread
- 4x4 fog lights in a 2wd valence?
- 1.5" wheel spacers to make rear match front after lift
- Rear Homemade Gap guard project Success!!!!!
- Changing brake pads/rotors on 98 f150?
- wtf?...
- fuse keeps blowing
- What is going on?!
- Rustiest 97+
- Can someone help me identify something?
- A few 99 F-150 XL questions
- Engine tries to die
- Truck is for sale
- Parking brake won't let go...
- 01 Scab Rattling Noise from mid to front area.. Help!!!
- door glass removal, screws or rivets
- Thinking about selling my EATON swap....
- 27.5 mpg hwy avg! 4x4 4.6L 3.55 gear ratio
- what could it be
- truck acting wierd (advice much appreciated)
- Front End replacement time
- Truck Overheating - 2002 4.6L
- Grease for front wheel bearings
- Got One
- Thanks for all the help you bunch of gear heads
- Motor swap in a 2002 ford f150 5.4L
- 2010 electric cooling fans? into a 2003?
- 98 4.2 iac
- 97 4.2 What GEARS to get question
- engineering test mode
- Need for speed on my 4.6L
- 97 f150 to 99 lightning suspension and brakes
- Headers
- another question about the driver seat and a cover
- can somebody post pics of their truck with 285/70r17 tires with just a leveling kit
- Truck died...possible solutions
- Paid it off
- Curious
- F150 Towing Weight & Hi-mileage Issues
- Can't balance my tires properly...
- rear tires getting very choppy
- 2003 Ford f150 5.4 triton
- Is this rust an issue?
- loud metal to metal grinding noise
- abs sensor replacement
- Gas Cap sucking in air.
- Benefits of changing the front end bushings
- need help with some questions
- 2002-2003 FX4 Owners
- Finally Got a Truck!!
- error code po113
- Aluminum vs iron calipers-98
- Lift Kit Questions...
- 2001 supercrew ring and pinion swap
- Fender Flares
- 2003 F150 s-crew
- EGR Valve
- what do ya'll think
- HELP mounts and rad support- not usual question? PICS
- 2x4 and mudding?
- How do I remedy this?
- replacement 7 pin plug for factory for tow package 2003 f150
- 03 on 24's burnout
- turning off interior lights
- changed sway bar link and feels like front end is falling off. ?????
- question about lift...
- Refabbed rear seat to fit two amplifiers. (03 FX4)
- '98 F150 SC towing?...
- Question about flow masters
- found a complete 5.4L Lightning motor and trans.. I share
- F150 4.6l whine and cylinder 1 help!!
- Better pics of true blue with the lift
- Help! Truck shaking
- E-fans and underdrive pulleys?
- New truck pics
- can somebody post a picture of their f-150 with a 3inch lift
- couple of questions about my ford... any help??
- looking for a real shock guide
- Anyone with a '99 with 5.4? Intake Manifold Question
- where to find sunroof gasket??
- Differential Difficulty
- Steering Mystery...please help.
- Battery light on at low rpms?
- Overhead Console Question
- in cabin air filter
- Best fuel octane for the truck.
- I bought the F150 for towing
- Mysterious Starting Problem
- need performance
- Regreasing CV joints
- Loose Steering and Eating Tires question
- New toy
- 97 Lariat 4x4 Transmission Filter
- Anything can be done: Powerstroke Swap
- Underbody Rust
- 4" Suspension lift shocks.
- Lean code problems 01 f150 5.4 146000 mi
- HELP... A lot of Questions
- Surprising MPG reading
- exhuast size
- 4.6l engine transplant/upgrade
- Finished a few upgrades
- Broke down and got something better on gas
- Wheel size compatibility
- stampede 8403-2 pocket style fender flares
- update and showoff, pic heavy
- ABS Problems with codes AND a pic
- What's it called?
- newb question
- What would you pay?!
- Sputter in my 2001 F-150
- Never buying a Dodge again!
- After turning off.. sometimes wont restart.. have to wait
- Leaky windows
- Odometer does not work.
- 2v to 3V?
- Coil Pack Problem
- Sub box diagram and dimensions for s-cab
- How to fix compass and temperature readout LED(part 1)
- early 2004 f150 (still 98-03 style) seat install into 98
- Antenna Removal
- Lowering 4x4 questions
- Axle Weights??
- Suspension
- King Ranch features
- 2002 with 4 codes please help!
- travel trailer
- noise in the rear end
- replaced the CMP but still a light squeek
- plug unplugged 2000 f150 5.4?
- Black bumpers??
- Fog light switch need help
- new guy w/engine problems
- Fuel Pump Problem??
- 03 Ford F-150
- 1998 F150 fuel pump replacement
- What will fit?
- 2001 f-150 7700
- 01 f150 4.6 flat spot at 2000 rpm
- Gauge pods
- Help needed with King Ranch seat swap into XLT
- gages vs starter
- how do you take off the grille shell?
- 1998 F-150 speedometer not working
- New guy here with a couple quesions,,
- traction bars mounted and tested!
- Heater smells like antifreeze
- Leveling kits+ mud tires post pics
- Will superduty taillights fit?
- What offset wheels for 37's?
- Truck feels like it has an engine break...
- Heater issues on my 2003 F150
- Got in a wreck.
- Global COP
- 97-03 2WD that have the 7.5 Fabtech lift
- 1badass4.6
- 2002 screw whining noise?
- Used 2003 XLT 4x4 Question
- lowering where to measure
- Battery light
- Guess this is my intro thread
- Dash lights out
- help. engine problem
- Access to pax fender vac lines?
- Wiring an aftermarket tach
- Washed motor runs rough with hard shift and shoots code P1747
- Child Seat Anchors
- Gotts Mod
- Lift
- my parking lights wont shut off
- 98 F150 Electronic 4wd not working
- What truck are these running boards for?
- 97 F150 4x4 Rims
- help diagnose
- 2000 F150 Frame
- Looking for verification on speed related vibration
- crap foglights
- Gas tank leak.
- Any guesses?
- Do I need special lug nuts?
- Before everyone was all about the Gotts intake what CAI was being used
- Tire load rating question
- Got most parts for my Eaton Swap, swap soon..
- 2000 4.6 warm start long crank and raw gas smell
- factory step boards got to go
- does the P1000 drive cycle reset need to be in order?
- limited truck???
- Removal of a hydrolocked 4.2 V6
- 35`s with torsion bars cranked?
- Has anyone heard of this?
- gauge cluster problems
- 4.2 engine swap problems
- Tire question.
- Starting problems - not fuel cutoff, not theft light
- Need Help Deciding
- Interior Chrome Door Handle Need Help!!
- 2003 or 2004 F150
- Thinking about getting a F150 with high miles.
- Advice/opinion
- Power steering complaining
- My Truck
- Brake pulsing issue info and resoulition.
