crap foglights
Old Mar 13, 2012 | 09:49 AM
2088bob's Avatar
crap foglights
My night vision is getting worse i have 2002 shackand half short box i went out and got a new valance so i could add some additional driving /fog lights picked up the ones from spyder auto i believe a company called winjet also markets them
Pure **** i might as well just have 2 candles behind the valance what garbage every time it rains they fill with water i have seen kids flashlights with better lighting output
save your money people don't buy these pieces of junk
Old Mar 13, 2012 | 09:07 PM
pizzaman711's Avatar
You get what you pay for man, I'd recommend searching next time before you buy a set though. There's plenty of bad reviews of spyder's cheap chinese products.
Old Mar 14, 2012 | 12:33 PM
Raptor05121's Avatar
this.
Old Mar 15, 2012 | 08:42 AM
2088bob's Avatar
TO add insult to injury i also bought the valance to install these lights into
i sat down yesterday and very carefully measured my old valance which i hung on to and cut two very tidy 4" holes into it and am mounting 2 x100watt 4 " driving lights from princess auto behind the valence they work really well as i have had hooked up temporarily on the the truck for a while now
i will put other valence up for sale its brand new
Old Mar 15, 2012 | 02:19 PM
2088bob's Avatar
Here are the pieces of junk from spyder
this is what i should have done in first place
Old Mar 15, 2012 | 04:09 PM
Yeah those are H3 projector models with the CCFL halos. They're meant more for looks than performance. But even then they look hideous
Old Mar 15, 2012 | 04:28 PM
2088bob's Avatar
Boy did you get that right and once you have them returning them is so awkward they just about take more than 1/2 the price if you decide to return
Old Mar 15, 2012 | 09:15 PM
2088bob's Avatar
i threw a couple of 130 watt H3's in the lights and went out and aimed them after dark how does that old song go "I can see clearly now "
Old Mar 15, 2012 | 10:54 PM
Halverso_99's Avatar
Originally Posted by raptor05121
yeah those are h3 projector models with the ccfl halos. They're meant more for looks than performance. But even then they look hideous
^^^this!
Old Mar 16, 2012 | 12:37 AM
Careful now, 130W is quite a bit of heat for a tiny H3 and those housings. You do have the appropriate size wiring and relay for it too I hope?
Old Mar 16, 2012 | 08:15 AM
2088bob's Avatar
Raptor 05121 no need to worry the lights came with 100 watt H3's OEM
this is my company
these lights are of a very good construction yes they will get hot but i am confident the housings can take the heat no plastic in housings anywhere
130 watt lamp draws 9.6 amps @ 13.5 volts these lights are fed with 10ga wire which is good for 30 amps and there is a 40 amp relay ahead of the set
the lighting is all controlled remotely as i wanted to bring no wiring into the cab
my other toy
12.21@114mph 1188lbs full of fuel 208hp 196ft/lbs torque at 7100 rpm
Old Mar 16, 2012 | 02:14 PM
Johnnyford98's Avatar
I thought about buying those lights for my 98 but a guy told me they dont even fit in the bumper holes properly so i paid twice as much and got the much better quality depo fog lights which fit like factory and plug right into the factory wiring.
Old Mar 16, 2012 | 05:08 PM
2088bob's Avatar
Johnnyford98
i cut those holes in the valance myself your 98 has holes in the bumper for the driving lights does it not the later trucks had the lights in valance
i have the driving light valance and the cheap spyder auto fog lights the valance is for sale and i will throw in driving lights if you want them
Okay i just reread your post i understand what you mean now i just want to warn people to stay away from the crappy spyder auto lights so you don't get stung like i did
my truck did not have factory wiring for fog lights my lights are activated by a remote control wiring system i built
Old Mar 19, 2012 | 02:20 PM
Yeah mine are in the chrome bumper but i have heard nothing but bad things about those spyder lights in general. On the 97/98 like mine all the bumpers had the holes but on some like mine instead of lights it just had black plugs that are bolted in but when you remove them the factory style lights bolt right in and luckily even the trucks like mine that came with no lights the plug is still under there i guess in case anyone ordered them at the dealer they could just plug them in.Too bad for you it sounds like you went to alot of time and expense to make those lights work.
Old Mar 19, 2012 | 08:51 PM
msk59's Avatar
2008 Bob: How did you secure the lights to the valance? A picture may help me understand how to secured the lights.
