need help with some questions
Old Apr 7, 2012 | 02:11 PM
realtreef15097's Avatar
how do i get past the air bag, safley unpower, and remove it so i can replacing my cruise control switched(grabbed new ones from junk yard.
any basic information for taking the dash apart to switch guage clusters would also be much appreciated
also when i start the truck and ever so often driving down the round there is 4 series of 5 dings that go off and i would like to know the cause of this to correct it
thanks in advance, Aaron
Old Apr 7, 2012 | 07:47 PM
bump
Old Apr 7, 2012 | 07:57 PM
c.frank47's Avatar
To remove the air bag you need to diconnect BOTH battery terminals and wait about 5 mins. Then right behind the battery you will see where a battery cable connects to a terminal on the firewall disconnect that and wit again. This will keep your airbags from going off at inoppurtune moments. There are links to remove the dash in the search section and also in the how to ( how to replace heater core ) Hope this helps
Old Apr 7, 2012 | 11:16 PM
Do you know anything about the dingin
Old Apr 7, 2012 | 11:22 PM
str8t six's Avatar
seat belt chime?
Old Apr 8, 2012 | 07:18 AM
Red02FX4's Avatar
Steering wheel:
https://www.f150online.com/forums/ar...3-f-150-a.html
Gauge Cluster:
https://www.f150online.com/forums/ar...r-97-03-a.html
If you are hearing a chime while driving, I would think there would be a light on in the cluster to notify you of the cause. If the dinging IS from seat belt warning, there should be a process to turn it off in your owners manual. I did this one.
Old Apr 8, 2012 | 10:50 PM
no the seat belt being on or off doesnt seem to affect anything i have noticed the airbag light dont come on, thanks i did get the airbag off the steering wheel to put in the cruise switches
Old Apr 9, 2012 | 09:26 PM
could no airbag light coming on when i first turn the key cause this?
Old Apr 9, 2012 | 09:57 PM
AndersonS's Avatar
In my sister's Explorer, I also had to deal with a series of annoying beeps. 5 or so beeps every few minutes while driving. Turns out a loose connection under the seat triggered the airbag light. However, the bulb in the gauge cluster was burned out, so as a backup warning, the car beeps to warn you of a malfunction.
Replace the bulb in the cluster to stop the beeping, then fix whatever's wrong with the airbag.
Old Apr 9, 2012 | 10:12 PM
do you know the bulb size id looked in the manual but couldnt find it
Old Apr 10, 2012 | 12:10 AM
Red02FX4's Avatar
READ the HOW-To's Index !!!!!!! It's in there
Old Apr 10, 2012 | 01:52 PM
please post link i searched, found people talking aobut them but never saw the bulb size listed anywhere, i know the main ones are 194 but what are the other ones, for like the airbag
