newb question
one tell is if the tail pipe is in FRONT of the rear tire from the factory, it's an early build 97. If the tail pipe is BEHIND the rear tire, it's a later build 97.
My 97 has a build date of 3/97 and had the factory tail pipe BEHIND the rear tire...
Mitch
Mitch
**** i saw that when i checked it for rust the piped in front
is there any major recalls i need to look for now, i checked the gas tank straps they were in great condition for an older truck the truck has hardly any rust at all
Lots of recalls on a 97.. You should be able to go to any Ford Dealer and they will ring up the VIN and tell you what has or has not been done on your specific rig.
Off the top of my head that I 'recall' getting done myself since I've owned it (2001), there is something with the fuel lines going into the engine compartment... There is the cruise control deal and the fuel tank straps. My fuel lines were fine. They did the CC fix and they replaced my straps.
Mitch
Mitch
The CC fix was to keep the truck from catching on FIRE!
Something with where it is attached to the master cylinder and it overheats and catches the brake fluid on fire. The fix was putting an inline fuse in the connection..
Mitch
Mitch
wait so pre july and i need a different head unit for different headlights...
i think im august though... i still have the tailpipe ahead of the rear tire though... i know its one of the first month of the 10th gens though.
Not to argue, but i was under the impression that the only 97's that had tail pipes behind the rear tires had the 5.4 and the 4.2/4.6 had in front of the rear tire. but then in 98 everything had tail pipes behind the tire.
