where to find sunroof gasket??
Old Apr 2, 2012 | 01:08 AM
turbodgumby's Avatar
hey guys where are u guys getting a new gasket for your factory sun roofs in your supercrews??
Old Apr 5, 2012 | 01:08 AM
Wow nobody knows???
Old Apr 5, 2012 | 07:50 PM
Red02FX4's Avatar
Send a message to Tasca Ford on ebay. Hope this link will work for ya:
http://myworld.ebay.com/tasca_tpc&ss...84.m1543.l2533
Old Apr 5, 2012 | 08:53 PM
BlackFerret's Avatar
I had mine done several months ago, it wasn't leaking but it was dry rotted and the edges of the gasket were lifting up form the glass.
I just went to the dealer and had them order one, apparently it is a two piece part, it took about a week for them to get it in. Once it arrived, I went in and had them install it, big mistake. The tech that installed it did not look at the gasket closely enough and apparently there is some preforming built into it and the part that was supposed to be in the corner wound up in the back edge close to the center, needless to say it kept lifting up from the glass. I took it back and they ordered a new on and had the local autoglass come in and install it correctly and all is good (No charge the second time for either the gasket or the installation). I don't think that the gasket and the install together was much more than $150, but then again I know the manager from when we served together in the Navy, and he gives me a 20% discount.
My recommendation is that when you get the gasket, have an autoglass shop do the install.
After the install check the gasket. There is a small seam on the rubber from when they mold the gasket and that seam is supposed to be dead center at the back edge of the glass panel.
