error code po113
error code po113
99 ford f-150 4.2,"service engine soon" I pulled error code po113,so I replaced the Iat sensor, I cleared code with scanner, and drove it, lite comes back on every time,"Please"! someone give me a clue,better yet a solution
You missed going to a more indepth discription of the code.
The code says the voltage expected from it's output is too high (the error).
Look for a connector issue, an open in the harness or a short to battery.
Good luck.
Good luck.
You were right "Bluegrass",wires for my IAT sensor were rubbing on the alternator housing since 1999,and it finally wore an almost complete break on the wire, not to mention it was probly grounding out as well ,I repaired it ,and so far no "Service engine soon" light,"THANK YOU SO MUCH"! for your advice,I hope you have a wonderfull Easter
