new guy w/engine problems
Old Mar 23, 2012 | 04:33 PM
sickcustoms's Avatar
Hi, so I found this forum because of the dreaded blown plug issue...I have a 98 lincoln navi with the 5.4L triton motor..Not sure what exactly the cause of the blown plug is, engine has a little over 200,000. the tip of the plug that got blown is also smashed into contact with the electrode. is there another issue that is at hand or will the time sert repair fix everything?
located in the bay area, CA. Do mechanic work as a living but first time experiencing this and don't want to shell out 400 for the correct tool...
Old Mar 23, 2012 | 04:38 PM
Welcome! I am going to move this so you will get more comments on your proble.
Timesert is a permanent repair of the problem. Just don't try Helicoil. There is a member here that rents out the Timesert kit, if you need one.
Old Mar 23, 2012 | 04:50 PM
thanks, yea i sent him a PM already. I'm just hoping that the crushed tip is because of it jumping up and down and it hitting the head. I have nightmares of the piston hitting the spark plug causing the crushed tip to the electrode but am hoping for the best...
Old Mar 23, 2012 | 04:55 PM
Old Mar 23, 2012 | 06:34 PM
Borescope it.
Old Mar 23, 2012 | 08:12 PM
Toyz's Avatar
It is more than likely from bouncing around in the plug well. A piston would have destroyed it in a fraction of a second. And there should be no reason a piston can reach the plug.
Old Mar 26, 2012 | 09:54 PM
yea, i kno that if a piston were to actually be able to reach the plug it would only be because of catastrophic internal damage.
Anyone know if the cheaper kits online work (inserts, not helicoil) or do I have to go with the $400 Time Sert kit?
Old Mar 26, 2012 | 09:55 PM
Originally Posted by glc
Borescope it.
i would if i had one..
Old Mar 26, 2012 | 09:58 PM
MGDfan's Avatar
It's either Timecert or these folks: http://www.blownoutsparkplug.com/contact.htm
They are in CA ....
The other alternatives appear to not be reliable .
Good luck.
MGD
Old Mar 26, 2012 | 11:20 PM
RENT a borescope from a tool rental store or an auto parts store.
RENT a Timesert kit from member "Galaxy". (Least expensive alternative that WORKS)
OR:
Have Ric or Dave come up from SoCal to fix it. (Refer to MGD's link)
OR:
Drive it down to them on 7 cylinders, all you have to do is unplug the fuel injector.
Old Mar 27, 2012 | 12:43 AM
jethat's Avatar
Thats just from it bouncing out probably. When I had an ejection it busted the ground strap clean off. Timesert is easy.
Old Mar 27, 2012 | 12:50 AM
jethat's Avatar
The (timesert) kit i have retails for around $160 then you gotta have loctite some 3 in 1 oil or grease and insert(s) it worked just fine and I was into it less then $200.
Old Mar 27, 2012 | 12:53 AM
jethat's Avatar
this is video instruction with the kit i used
http://www.youtube.com/watch?v=Ntiy8L97Nco
I bought it here
http://www.mechanicstoolsandbits.com...6d79b502b46b6a
Old Mar 27, 2012 | 07:10 PM
I will send him a PM
OR:
OR:
Old Mar 27, 2012 | 07:47 PM
InDaRed2's Avatar
Looks just like my plug that blew out. Mine worked its way loose and blew out the last thread. I was able to thread a new plug back in and it seemed to catch the same amount of threads as the other plugs. Hopefully it doesnt blow out again but I am checking to make sure it is tight as often as I can.
