Will Trade A Funny, Funny Story for Advice
Old Mar 2, 2021 | 05:01 PM
oldpops's Avatar
This post could also be titled:" How I turned a simple auto diagnostic session into an insurance claim".
First: We have a 2001 F150 Super-crew (5.4L/2V, auto-trans, 2 wheel-drive, 225,000+ miles), that has developed a coolant leak. Every morning we see a coolant puddle underneath the passenger side of the truck, below the the firewall area. My son and I have looked at all the usual areas of leaks on this motor (around the intake manifold as best as we can see, the coolant crossover pipe, around the thermostat, the heater hoses as they come through the firewall, and even inside the cab on the carpet and below where the heater core is located & found nothing. There is no coolant in the V8 valley/well behind the alternator, and we don't see any leak at the heater hoses at the back of the engine (off the metal nipple that frequently breaks on the end of the hose that runs underneath the manifold). We have done a pressure test & used mirrors, jumped up on the engine, and even used a borescope, but we are unable to find the exact source location of the leak. All we know is that the leak ends up dripping off a screw that is on the bottom of the truck, behind the front right passenger tire. Obviously the leak it is coming from somewhere else and ending up on the screw. Can't fix it till we know where it is actually coming from. Any advice suggestion on what else to do or where else to look is appreciated!
Now for the funny story, well funny for you guys - not me. In our efforts to locate the leak, my son and I tried to see from below, but my truck doesn't sit up high enough. Couldn't find our floor jack but did have a ramp. Since we needed to get under the truck just behind the left front wheel, where the screw is that is dripping the coolant, I had the bright idea of putting the ramp behind the wheel, with the incline part facing the front of the truck. That way we could back up the truck, & lift the truck up enough to get under the truck right behind the front passenger wheel. Well, I should also tell you that we live on a steep hill so i should have had some blocks or something back there to stop the truck in case of disaster. WHOOPS!
Well, my son was down next to the right front wheel giving directions with his hand. As the truck backed up and started going up the ramp, I had to lean over to the passenger side a bit to see my son's directions. Well, the truck went too far and fell off the ramp, and did so with such a thump it apparently triggered the fuel pump cut-off because the engine died. At the same time, since I was leaning over to the right side of the car, I lost my balance and fell onto the passenger side of the front seat. Needless to say, the truck went backwards, building up speed due to the hill we are on. I was trying to pull myself back up so i could see and then get control of the truck. Since I was basically laying on my side,my foot was no, longer on the brake. And while I was pulling on the steering wheel to get up all I was accomplishing was that the truck rear and careened toward my neighbors yard.
As I went across a little piece of new lawn between our driveway and our neighbors property, I managed to miss a tree and a fence - which is hard to do when you can't see where you are going, and you are going backwards fast down a hill. However, I was able to use the rear end of my neighbors (almost new) car to stop my truck. My first concern was my son since he was down where the truck front wheel was, but I was quickly relieved when I saw him running down our driveway. Of course once he found out I was OK he had to turn his face away to make I didn't see him laugh! My neighbor's wife came out and I told her that i am sorry, & that I did have insurance. She called her husband, who had just left on a motorcycle ride to clear his head, & told him what happened, & to come home. When my neighbor did get home, I came over and apologized, gave him my insurance info. It was then my neighbor told me he would have been home when it happened but that his mom had just died (she lived with him) so he wanted to be alone for a little bit. I felt even lower after hearing that.
In any event, my insurance company is involved and told me they will take care of my neighbor's car. They also told me my rate will probably go up because of the cost to fix my neighbor's car. My neighbor has pretty cool about the whole thing but i feel like crap. Plus, along with my body aching after getting bounced around inside my truck (i'm old and fragile), I still don't know where the darn coolant leak is. So any help and advice folks here could offer, I would greatly appreciate it!
Old Mar 3, 2021 | 12:58 AM
heater core could be leaking inside the airbox and leaking out the normal evaporator drain tube
Old Mar 3, 2021 | 09:59 AM
Veteran: Army
x2, seems like a for certain sign for sure
Old Mar 3, 2021 | 02:17 PM
oldpops's Avatar
Ahhhh..,where is the heater box drain tube? Any pictures/diagram so I know what to look for and where to look?
Old Mar 3, 2021 | 04:20 PM
It comes out of the firewall down fairly low. It's what drips when the AC is running.
Old Mar 3, 2021 | 04:48 PM
oldpops's Avatar
I feel so stupid for not knowing where the ac condensate drips out. I can ask my son to go back under the truck when he comes over but he will want to know exactly what to look for, and where to look. If any one has a picture or diagram of what the drain looks like or where it's located that would be great and I can show my son.. I would get under the truck myself but I am still a bit sore from being bounced around inside the truck during my infamous "Downhill, backwards, fish-hook turn, into my neighbors car, without looking trick!", which is now known throughout the neighborhood. Incidentally, the insurance claim rep wondered how I was able to do such a maneuver.I still don't know how to explain it.
Old Mar 3, 2021 | 07:40 PM
serotta's Avatar
Reminds me of "love potion #9.... "She bent down, turned around and gave me a wink".....
You don't explain that kind of luck, you just live through it and walk out the other side.
Old Mar 3, 2021 | 09:42 PM
It's the only hose that comes through the firewall that's open at the end, pointed down. Passenger side, down fairly low.
Old Mar 4, 2021 | 02:14 PM
oldpops's Avatar
Is it behind a piece of plastic by chance?
Old Mar 5, 2021 | 06:12 PM
JG_X2's Avatar
Yep! Happened to my 2018 Lariat - leak in the heater core. Took the dealer two days to make the fix. It's complicated.
Old Mar 6, 2021 | 10:03 AM
renn90's Avatar
hairline cracked overflow bottle?
sorry to hear about your mishap
Old Mar 6, 2021 | 10:05 AM
renn90's Avatar
heater core leaking behind dash, then under carpet, through floor, exiting behind left rear wheel?
Old Mar 6, 2021 | 01:23 PM
oldpops's Avatar
I tried to get a couple of pictures of the screw that appears to be the end point for the leak.The first picture/top photo is taken from just inside the left front tire(looking towards the screw). The second picture/bottom photo is taken from under the middle of the truck looking toward the engine. Sorry they are not as clear but my phone camera is about the same quality as just about everything else I own. Hope this helps.
Old Mar 6, 2021 | 01:49 PM
I know you want to try to fix this yourself, but it appears you don't have the needed equipment. I think it would be worth it to take it into a shop that can put it in the air and do a proper cooling system pressure test.
Old Mar 7, 2021 | 03:29 AM
its leaking higher up than the screw / threaded stud
