Leaf spring squeak
Leaf spring squeak
So I have developed a nice creek/squeak in my driver side leaf spring. it is the leaf spring itself, in the stack of them. I can spray it with WD-40 or any lubricant, and it goes away for a couple weeks, but I have done this a few times, and its just getting annoying. Is there any way to get rid of this noise for good? Taking them out and painting them or caking them with a grease or something?
-Matt
-Matt
jack the frame up so that the leafs seperate then clean them with soap and water and a power washer...also this happend on my brother tacoma what he did was jacked the frame cleaned them and put rubber like 1/8inch rubber in between them and lowerd the truck back down....hasnt had them squeek ever since and he goes through mud with it and gets it dirty all the time..mine are starting to do this so when i feel like not being lazy i'll do it to
Sbclurxc... Laziness is not an issue, it comes down to doing someting that has been proven to work.
Mud-Digger.. Thanks, I will have to run up to Tractor Supply and see if I can find something that will work.
-Matt
-Matt
my 02 screw is doing this as well glad I'm not the only one!! I like the rubber idea!! What type of rubber should I use? My dad has suggested using some old semi truck mudflaps for the rubber. He has a few of those lying around since he drives a gas tanker for a living!!
Just to clarify I wasn't insinuating you were being lazy all I was saying was the things you mentioned would work and trying to get someone to post somewhat of an easier method. Mission accomplished sorry if you took that the wrong way.
scblurxc.. Its all good man. Just had a ****ty day so really nothing would have went well with me LOL!
I like the mudflap idea, may have to get ahold of one of my guys over at our local semi shop.
-Matt
-Matt
