Brake fluid
Old May 14, 2014 | 08:47 PM
seagullplayer's Avatar
Brake fluid
We put dot five in my 2001 F150, one bottle. So it is mixed with Dot 3.
How bad is this, or is it ok?
Old May 14, 2014 | 09:23 PM
Apittslife's Avatar
Get it out ASAP!
Completely non-compatable.
Old May 15, 2014 | 05:50 AM
Thanks, I will plan to purge the entire system tomorrow.
I assume I want to refill with dot three?
Old May 15, 2014 | 06:38 AM
JCR 56's Avatar
Dot 3.
Old May 17, 2014 | 10:57 PM
I bleed the system when I got home from work Thursday. I opted to purge the system using Dot 3. I used my vacuum bleeder till I had good stuff coming out and then some.
The rear brakes didn't have any dot 5 in the lines, only the front two. I had only bleed the front brakes when I added the dot 5.
I have some in a qt jar in the garage, you can see it separate out!
I kind of got worried about my HD Sporster, that is what uses the Dot 5. I was afraid that I might have mixed it with dot 3 at some time. So I also flushed both brakes on it. My new dot 5 was purple, that made it easy to tell when I had the old stuff out.
But I saw nothing out of the way on the bike, so I think I was ok to start with. But I do feel better now.
Thanks for the heads up guys, this sure seemed like something I should have known.
