Severe miss
Severe miss
so I have codes po 135 po155 po303 po 307 and p1000?? I put new plugs wires and both coil packs on and it still misses pretty bad and once in a while (quite often) the light flashes at me in the middle of all this I had in the shop and had both manifolds replaced bolts rotted off I was too cheap for new cats and gutted them thanks for all your help
You have a problem with both front O2 sensors - heater circuit. Either both of them need to be replaced or you have a wiring issue.
What brand plugs, wires, and coil packs did you use? Did you do a compression test?
What year and engine?
