7700 questions
Old Oct 10, 2011 | 09:42 PM
archangel2003's Avatar
7700 questions
ok i found a 2001 f150 lariat 7700 4x4 ext cab for sale by me and i went to look at it once. the running boards are rusted out along with the trailer hitch receiver. its got a brand new exhaust. so i think it rusted out and was replaced, but the there isnt rust anywhere else. nothing was painted over to hide any other rust that i can see and i cant find rust anywhere else. should i be worried about this? what are some other areas i should look at to make sure the rest of the frame is in good shape?
Old Oct 10, 2011 | 10:12 PM
pizzaman711's Avatar
I'd crawl up under and check everywhere, they were made to be work trucks so not a lot were maintained like you would see a normal truck when it came to washing anything that could cause rust off. Check the bottom of the doors for rust too, like underneath them when you have them open.
Old Oct 10, 2011 | 10:14 PM
back of the bumpers is a common rust spot as well
but definitely check the pinch weld and drain along the inside bottom lip of the doors.
Also look at the side back corners of the cab (from underneath)
Old Oct 10, 2011 | 10:40 PM
And if the bed has one of those drop in liners, definitely check underneath that. And Patman at least you knew what I was trying to say haha, I couldn't think of what it was called.
Old Oct 10, 2011 | 11:04 PM
I got your back
Old Oct 10, 2011 | 11:12 PM
Raptor05121's Avatar
Meh, I'd run away from a vehicle that had rust (unless you plan to use it as a snow plow/work truck).
