Heat & Air Problem
Old Sep 19, 2014 | 05:48 PM
wooddaleguy's Avatar
Heat & Air Problem
I have a 2002 5.4L F-150. I had no heat. Removed dash and installed new heater core and thermostat. Now I have no heat or air. What is the most likely cure?
Old Sep 19, 2014 | 06:42 PM
projectSHO89's Avatar
You don't have any hot coolant circulating through the heater core.
Old Sep 24, 2014 | 03:24 AM
DLWTHIT's Avatar
When you re assembled it. Something has probably unplugged... is the fan still working but no air out of the vents??
Old Sep 29, 2014 | 10:32 AM
Yes I have good air flow
I have great air flow. Just no control over it being hot or cold.
Old Sep 30, 2014 | 08:43 PM
Did you plug the blend door actuator connector back in?
Have you verified that coolant is flowing through the core?
Have you verified that the refrigerant section of the air conditioner is operating when a mode that uses it is selected?
Old Oct 18, 2014 | 04:09 AM
Truckinal's Avatar
Sounds like blend door actuator and or blend door
