Ac problem
Old Nov 23, 2014 | 12:29 PM
Texaslax22's Avatar
Ac problem
I just fixed my misfire which was a coil. And I'm guessing we all know how bad of a spot those are in. Anyways after fixing the problem it seems as if when I accelerate the ac kicks up to my dash but when im cruising or ideling it blows through the normal vents. Could it be possible that I accidentally pulled a hose out and that's the only problem?
Old Nov 23, 2014 | 01:03 PM
Look at the small hard vacuum lines behind the battery. They frequently crack.
Old Nov 23, 2014 | 03:16 PM
projectSHO89's Avatar
You do have vacuum leak now, so go back and check your work area.
