running a -6 offset with no issues, can I run a +1.00 ?
Old Oct 12, 2012 | 08:16 PM
West Tx F150's Avatar
found some fuel wheels and was wondering if I will have any issues running these http://www.4wheelparts.com/Wheels/D5...HTD52516809545
Old Oct 12, 2012 | 10:40 PM
97madness's Avatar
SHould be fine. but they will look like they are sucked really far into the fender.
Old Oct 13, 2012 | 01:13 AM
Buxton91's Avatar
You can fit them just fine. They will sit inside the fender just a hair more than your current wheels. An 8.5" wheel with -6 offset and an 8" wheel with 0 offset have the same backspacing of 4.5"
Old May 24, 2013 | 09:06 PM
2000FordStyle's Avatar
I know this is an old thread but I was looking at some wheels that are the following
16x8.5 with a -6mm offset and 4.5 backsapce. Will they still sit inside fenders on a 2wd ???I dont want something that sticks out...
Factory wheels are the 16x7 with Ford 5 spoke...
Old May 26, 2013 | 02:03 AM
Buxton91's Avatar
The backspacing is still the same, but because they are wider they will stick out 3/4" further than your current setup. I doubt it will be that noticeable however.
