Headlight HELP
Old Nov 21, 2012 | 01:59 AM
stroked_89's Avatar
Headlight HELP
ok so i have a 1997 f150 and i want to put aftermarket headlights on my truck, but apparently, the 97 and 98 are diffrent from the 99-03s, so i have to change out the front end. how did u do the mod? i dont want to change the whole front end is it possible to just change the header panel and it will be all good?? or if i change the header panel i need to change the grill surround and bumper? thanks,,
Old Nov 21, 2012 | 11:54 AM
chrmar's Avatar
As long as your truck was built after 07/96 the headlights are the same from 97-04. If your truck was built before 07/96 there's only one or two direct fit aftermarket lights available, I believe. Or, you can swap the header panel to the newer style.
Old Nov 21, 2012 | 01:28 PM
Raptor05121's Avatar
Yeah you need to change header panels. The bumper and grille surround can stay the same.
Old Nov 21, 2012 | 04:56 PM
WD40.1's Avatar
You shouldn't have to change/mod anything.
Any 97-03 lights should swap right in.
I put '00 (I believe they're '00) Lightning headlights in my 98.
Took me all of 10 minutes to change out both lights.
Old Nov 21, 2012 | 05:16 PM
stroked_89's Avatar
ya was your truck i saw i was like wth how u got those lights! anyway, mine is the one with the 2 tabs behind each headlight.i dont want to order and waste money!
Old Nov 21, 2012 | 05:17 PM
stroked_89's Avatar
my lights come out 1 pc not 2 pcs.,
Old Nov 21, 2012 | 05:24 PM
WD40.1's Avatar
Mine has the same 2 tabs on the headlight that you pull up on to release the light.
The side markers/turns have 1 screw each.
You mean your headlight and side marker/turns are one unit?
Are they like this?
(Build date before 7/01/96)
http://www.1aauto.com/1A/HeadLights/...55/434094/1997
I guess you do learn something new every day.
I've never seen that type before.
These are the ones I got:
(Build date after 6/96)
http://www.1aauto.com/1A/HeadLights/...ampaign=1ATony
Old Nov 22, 2012 | 01:28 PM
stroked_89's Avatar
yeah mine are the one pc ones, i just bbuffed them with plastic x,,could be better wit aftermarket headligts.
