AC Compressor
Old Jan 10, 2018 | 11:36 PM
Cody Banks's Avatar
AC Compressor
I have a 2002 Ford F150, im having to remove the ac compressor it has started putting off a burning smell, i cant find any videos on how to remove it, if anyone has a video id appreciate it.
Old Jan 11, 2018 | 12:34 AM
I assume you are going to replace it? If not, you are going to need a bypass pulley kit. By law, the system has to be evacuated and the refrigerant recycled.
https://www.autozone.com/cooling-hea...lley/ford/f150
Old Jan 11, 2018 | 07:15 AM
projectSHO89's Avatar
Check for a failing clutch and pulley first. Lot cheaper and easier than swapping the whole compressor.
Old Jan 11, 2018 | 10:37 AM
Roadie's Avatar
I found these videos. I haven't reviewed them.
Old Jan 12, 2018 | 05:07 PM
AC Compressors don't go bad unless you have a leak in the system, or it was over charged. The first thing that goes is the clutch. You can easily buy a clutch kit off ebay, and install it yourself. The hardest thing to do is set the clutch on it. I recommend the thickness of a business card. I've rebuilt a fair share of them in the past 5 years for people.
Old Nov 20, 2022 | 07:33 AM
Kenny Harrison's Avatar
[QUOTE=ManualF150;5229250]AC Compressors don't go bad unless you have a leak in the system, or it was over charged. The first thing that goes is the clutch. You can easily buy a clutch kit off ebay, and install it yourself. The hardest thing to do is set the clutch on it. I recommend the thickness of a business card. I've rebuilt a fair share of them in the past 5 years for people.[/QUOTE
Is there a way to force the compressor pulley to turn? Whether it works or not?]
Old Nov 20, 2022 | 08:47 AM
Yes, just tighten the clutch snug with the face. It will act as if the system called for it without electricity.
After testing, you'll need to readjust the clutch to about business card thickness away.
Old Nov 20, 2022 | 03:40 PM
The pulley should be turning any time the engine is running since it's driven by the serpentine belt.
