Lift questions.
Old Jan 24, 2012 | 12:00 AM
03F15003's Avatar
Arrow Lift questions.
Hey everyone, new to the forums. I have a 03 f150 2wd and i am currently running a 3" body lift along with a 3" spindle lift and 2" coils. I have 33" mudders with room for 35s possibly. i want to go bigger and run 35s and regear. Will there be anymore stress then there already is on the suspension if i take the 3" spindle and 2" coils off and put on this 6.5" Springtech lift? i will post a link. If anyone has it, tell me the pros and cons. Thanks ! Lift Kit 6.5" - 97-03 Ford F150
Old Jan 24, 2012 | 12:05 AM
03F15003's Avatar
http://app.infopia.com/Shop/Control/...9037/SFV/32526
There's the link.
Old Jan 24, 2012 | 12:09 AM
BOOMER2011's Avatar
wait all you need are the upper control arms and 1" space to get that same amount of lift cause i Just did the same thing to my truck i sust removed my stock coils with a 2" spacer and put in 3" Lifted coils
you can order them form doestch, they are all the same.
Old Jan 24, 2012 | 12:12 AM
03F15003's Avatar
yeah my angles are bad right now so having the new control arms would make a bigggg difference
Old Jan 24, 2012 | 12:14 AM
BOOMER2011's Avatar
they did for me, but im fixing to change that hahaha im going to put a 1.5 spacer in when i get new tires
Old Jan 24, 2012 | 12:15 AM
03F15003's Avatar
you have a current pic of your set up? what size tires you got?
Old Jan 24, 2012 | 12:17 AM
Buxton91's Avatar
Just order the control arms and 3" springs. Then you'd basically have the full lift except for your spindles being a 1/2" shorter. canuckmotorsports.com usually has the best prices.
Old Jan 24, 2012 | 12:18 AM
Buxton91's Avatar
If you have any questions or need pictures just let me know. I have the 6.5" and a 3" body lift, the same setup you're wanting to run.
Old Jan 24, 2012 | 12:19 AM
03F15003's Avatar
i mean i do have a 1.5" spacer sittin' around in the garage
Old Jan 24, 2012 | 12:20 AM
BOOMER2011's Avatar
yea i got mine from Gordie's Speed Center in Arizona, the shipping for the coils and CAs and alinement bolts was about 500$ shipped
Ill trade you for a 2" spacer hahaha
03F15003's Avatar
Honestly buxton, you inspired me on the lift lol i have been reading around but decided to make a post of my own.
Old Jan 24, 2012 | 12:21 AM
03F15003's Avatar
and i may just end up running the spacer as well, not sure yet ha
Old Jan 24, 2012 | 12:24 AM
BOOMER2011's Avatar
we both have the same lift hahaha
Old Jan 24, 2012 | 12:26 AM
03F15003's Avatar
boomer, do you have a current pic of your setup? running 35s too?
Buxton91's Avatar
I'm glad to hear that man. You should be able to run the spacer with this lift as well. Your angles would essentially be the same as a stock truck with a leveling kit. I actually had some slight positive camber after installing the new springs and control arms so if I would have put my old spacer on beforehand I would have been able to get an accurate alignment. One of these days when I finally order an add a leaf I'll be putting it back on though.
