Roll bar finally done
Took me a few months with a few days here and there measuring, cutting and welding. Wiring the lights was fun too as I wanted the outside to be on switch and the two middle lights to be on a seperate switch.
Painted the light housings black. Spraid the roll bar with bed cover several times.
For those who didn't see my previous post, it started as a Ram roll bar.
Had to take several inches out the middle and also had to cut the rear legs off and extend them.
IF I were to redue it again I would have redone the angle on the rear legs and taken it back even further.
Feel free to leave comments. Negative "OK" too
I added a touch screen that allows 3 things to be powered. Mounted just about flush to place I mounted it. Very nice vs the usualy toggle switch.
pics:
and those are stock rims with 35" tires if you were wondering.
Thanks for looking.
pics:
Thanks for looking.
. That should open up your "what to look for".
I'm been reading up on getting a Stick welder and converting it over to a TIG. I'd like to get into tig welding for the smoother nad nicer welds.
My lincoln does a decent job for what it is. I really need to put some cash aside and upgrade to a nicer one. Only having 4 head settins sucks
.I need more control and better duty cycle.
Thanks!!
I'll try to get some pics if I remember over the weekend. Cant make promises though. So much going on with projects.
I'm currently cutting up a large metal cabinet to use the steel to replace my rockers on both sides.
Also picked up a 4" cowl hood off a mustang that I plan to work into my F150 hood.
