Help with suspension lift
i have a 2002 F150 XLT FX4 and i want a 2" lift kit and i am looking at a
Rough Country
97-03 FORD F150 2.5 INCH SUSPENSION KIT W/SHOCKS and TYPE 6089 CHROME 17x8 - PRO COMP WHEEL with Extream mud terrain pro comp 265X70R17E (31X10.50R17) tires
My question to you is this why is that this 2" lift kit has a 1" block and others have a 2" block and (W/add a leaf) Do i need them?
Also should i use 285x70R 17 tires instead and what about the rim's size ?
Rough Country
yeah lifting a truck and then putting 265s on it is pointless. you can run 295's just by cranking the T-Bars a little...
Personally, I wouldnt waste $$ on a small lift like that. If it were me and I only wanted a small lift Id just get a 3" body lift.
If you're gonna spend $$ on a suspension lift I'd get something worth getting, like a 4".
If you're really just wanting to put a little bigger tire on it, just crank the tbars and slap the 295's on it.
thanks guys i see what you mean about the key's but what 4" lift do you think i should buy then with the shocks give me a link to it as well and what ever i need to go with it to make this sucker work as i will be home in april from afghanistan to test this puppy out. and i will go with the 285x70R17 tires and rims as well to go with it.
I wouldnt lift it if you are only gettting the 285's. they would look small with the lift.
besides, you can run 285's without any lift.
