Ciol Pak
Old Jan 25, 2011 | 10:42 PM
trailhunterf150's Avatar
Ciol Pak
ok so every time i go muddin i always seem to blow a coil pak. Any tips on how to keep this from happening so much or if i can upgrade coil paks?? i know goin through a couple feet of water is never good but, im just hoping that maybe it wont happen everytime.
thanks guys
Old Jan 25, 2011 | 10:54 PM
jbrew's Avatar
Well, 2' of water lol. You should goop a bunch of dielectric grease on the crank sensor. It's @ the bottom of the engine and if water invades that one, it will leave you stranded, = no start.
As far as the pack. Silicon wire sealer will help, I might even use dielectric grease where I can on the pack itself. It won't last forever tho, most dielectric will solidify in time. I'd check it every 6 months or so.
