motorvac
motorvac
Well i have some questions. I did a search and all i could really find was that it is supposed to help clean things. I guess what i am wondering is what exactly gets clean, should it be done before or after new plugs/ o2 sensors, and what is the difference between motorvac/ bg service? thanks for any info on this, once it gets properly warm i am going to fix my exhuast leaks/ replace my o2's and do a new set of plugs and i was planning on cleaning my tb and then i heard about this.
It's like an upper GI to us humans. I get the MotorVac every 3 years or so. Truck has 279,000, gets 16 mpg empty/no trailer (city and hw) and doesn't use a drop of oil between changes, even when pulling it's own weight.
http://www.dynatune.com/motorvac.htm
A Motorvac and a BG job is essentially the same thing. Most shops around here use BG because they are based in Wichita. It's supposed to clean out the entire intake tract starting with the throttle body all the way into the combustion chambers. I'd do it before a plug and/or O2 change.
I do not know if it effectively cleans out the EGR ports in the throttle body.
well i have a 4.6... so does that mean i should do it myself and then run some carb cleaner/ seafoam through the system? or should i clean it myself and then take it in and have a motorvac done?
Clean it yourself, Motorvac and forget the snake oil.
Well, FORD recommends it, - they recommend it for the three valve only and as a plug TSB. It does allot for your internals. It won't work miracles, but if your keep up on it, you can keep it clean inside that way. Keeps the valves spotless for one, and the tops of the pistons.
