Pre 7/97 Headlights to later conversion
Old Feb 10, 2011 | 01:26 PM
jar527's Avatar
Pre 7/96 Headlights to later conversion
I have an early 97 XL that I would like to upgrade the headlights on. The problem is that the headlights mount differently on trucks built after 7/1996. Headlight options for the early 97 models are limited (LMC truck has stock and Euro, thats it) so I was wondering if anyone has ever tried or seen the later style headlights being modified to fit the early 97's bracket?
Thanks!
Old Feb 10, 2011 | 01:49 PM
dirtyd88's Avatar
If I remember correctly, you can buy a header panel and the other parts needed from a 98 and swap them. But I'm just stabbing in the dark on that...
Old Feb 10, 2011 | 02:30 PM
Raptor05121's Avatar
you're right.
Old Feb 10, 2011 | 02:32 PM
dirtyd88's Avatar
you're right.
Woohoo.
Old Feb 11, 2011 | 08:30 AM
jar527's Avatar
Thanks guys, that doesn't sound too bad. I appreciate the help.
Old Feb 11, 2011 | 10:19 AM
dirtyd88's Avatar
No problem.
Depending on the availability of the parts at a local junkyard, and depending in your location, you may be able to grab the majority of the parts from here --> www.Certifit.com
Old Feb 11, 2011 | 01:27 PM
I got my header panel for $35 IIRC off www.partsgeek.com. Shipping may be a bit steep though
Old Apr 14, 2011 | 12:29 AM
Stephen87's Avatar
sorry about bringing back and oldish thread
so all I need is the header panel and that is it or is there something else
Old Apr 14, 2011 | 12:56 AM
Buxton91's Avatar
What is the build date on your truck? If I recall correctly, trucks built after 7/96 don't need the header panel swap.
Old Apr 14, 2011 | 01:07 AM
Stephen87's Avatar
02/96 is the build date
Old Apr 14, 2011 | 01:16 AM
Buxton91's Avatar
Then yes, all you will need to do is swap out to a newer header panel.
Old Apr 14, 2011 | 01:23 AM
Stephen87's Avatar
sounds like a plan, thanks for the info
Old Apr 15, 2011 | 05:00 AM
Stephen87's Avatar
anyone know where I can get the tabs for the headlights to hold them in place
Old Apr 15, 2011 | 05:06 AM
five0merc's Avatar
Off of any truck at the junk yard. Other than that I am not sure. That is what I did.
Old Apr 15, 2011 | 08:26 PM
Stephen87's Avatar
well i got 2 from the dealer for 8 dollars a piece just to hold me over till I can get the other two and then all I need is the screw that holds th corners in
