4x4 Went out and this is what he charged?
Okay so many of u know my 4x4 went out and i took it to my local mechanic and here is what he charged me for everything.
Front Diff bearing ***-278.40
Front Locking *** Control-368.38
Press Baron-30.00
Rear End Open-49.60
Labor/ Front Diff-225.00
Total-951.38
Did I get ripped off or What? I dont even know what some of this stuff is and whats the cost of it?
Press Baron-30.00
Rear End Open-49.60
Total-951.38
Press Baron-30.00
Rear End Open-49.60
Total-951.38
Press Baron-30.00
Rear End Open-49.60
Total-951.38
I had all the labor done. It cost $200 plus a case of beer. That included pulling out the Diff, Pressing bearings, disassembling the diff for the axle shaft and housing, and setting up the gears.... The labor wasnt bad but really stuck it to you on the parts..
It cost me about $200 (+) to get my 4WD fixed. The problem was minor apparently. I can't remember off hand, but they said there was some piece "binding" or not being fully exercised. Can't remember right now. The switch worked and it could be heard activating, so it wasn't that. I just tried to dig up my service ticket on this and can't seem to find it.
There has been many threads about non functional 4WD on this forum.
TM
TM.
TM
TM.
Was curious why swap in the A4wd right axle and housing.
Rus- The A4WD Right axle is solid, instead of having a slip collar. It removes the need of having the front differential shift fork, and vacuum lines running to the front diff. Granted it does make a little mileage decrease as everything in the front diff is now rotating all the time, but it makes the entire front driveline a little stronger. Also having a locker upfront has a tendency to break the shift fork. With looks aside my truck see's its far share of off roading on the weeks, taking care of the property and getting back to our hunting camp. It also just makes the entire ESOF systme that much better in my opinion because, Now even if i have a solenoid failure, I still have 4wd..
