wheel bearing going bad?
Old Feb 5, 2011 | 09:30 AM
johnstonblake's Avatar
i've got a noise at low speeds (~20 mph) that sounds like tire noise. the only thing is that it really only sounds like it's coming from the front left, and still sounds like it's from the front left after i rotated my tires. i guess the only other things it could be is a bad wheel bearing (which was replaced last year), or a warped rotor. the sound increases slightly when turning to the right at the same low speeds, i really can't hear much at higher speeds.
i had that exact wheel bearing replaced about a year ago at firestone, i guess i could take it back to them and have them check it out?
whatcha think?
it's a '03 F150 FX4, BFG all terrains.
Old Feb 5, 2011 | 10:01 AM
Red02FX4's Avatar
Sounds like it. Jack up the front wheel off the ground and with your hands on top and bottom of tire... see if it moves in/out at all. Then try side to side. When my wheel bearing went out, I jacked the wheel and it had sooo much movement I felt lucky to catch it in time
Old Feb 5, 2011 | 10:04 AM
cool thanks, did you hear it before anything else?
Old Feb 5, 2011 | 11:09 AM
TJ8769's Avatar
while you got it jacked up id check the cv joint too its another possible cause of that sound.
Old Feb 5, 2011 | 11:12 AM
how do i check the cv joint?
Old Feb 5, 2011 | 12:30 PM
Red02FX4's Avatar
CV axle for the front wheel drive... just inside the rim and comes though the hub bearing. Check for a broken accordion styled boot. This will let dirt and grime into the grease for its u-joint. They usually make a click-click-click sound when bad
Old Feb 5, 2011 | 12:34 PM
Red02FX4's Avatar
I had to drive my truck.... for company business... to South Carolina from here in Delaware. And against better judgement... another bus driver drove it home. Then he called and said it was "making a noise". When I got back and went to head home, I was like HOLY S**T! From my experience, first thing I did was check the wheel
Cost me $250 to fix it (which the company would not pay for) and had to take off work 'cause it ain't goin' nowhere
Old Feb 5, 2011 | 12:59 PM
Galaxy's Avatar
It doesn't have to have any play to be bad. I had a thread going just last week...my front left was headed south but I had no play in mine. Just the "sand in a jar of barbells" sound. If it's the hub, the pitch/tone of the sound should change with speed instead of turing. Jack the wheel up off the ground and give it a good 'ol spin and see if you can pinpoint the sound.
Old Feb 5, 2011 | 03:05 PM
jbrew's Avatar
Also, make sure it isn't your PCV valve. Might sound funny, but they can mimic that sound at certain speeds. Must run a Motorcraft valve only for these engines.
