blower motor
Old Jan 20, 2015 | 08:39 PM
jorge491's Avatar
blower motor
I have a 2004 style side crew cab and blower motor works only after going over road bumps. Replaced relay but only fixed problem for a while. When it comes on all speeds work fine and I can turn it on and off. It happens two or three times a day. Any ideas would be helpful.
Old Jan 21, 2015 | 07:22 AM
JCR 56's Avatar
Sounds like a loose connection.
Old Jan 21, 2015 | 09:05 AM
MGDfan's Avatar
1. This is the 1997-2003 section.
2. There is an electrical-specific section - ask a Mod to move yer Q there?
3. You'll need to do some basic troubleshooting - if that's beyond you, take it to a shop. Pop the hvac control panel and check the connections. Remove & Inspect the resistor pack, and it's associated connector. Yer looking for burns/corrosion, looseness, etc.
https://www.f150online.com/forums/ar...emtc-hvac.html
https://www.f150online.com/forums/ar...igh-speed.html
4. Avoid any bumps
good luck
