Please Help No Start
Old Apr 23, 2015 | 12:14 AM
miked79928's Avatar
Ok, so this afternoon the paddle in the shift column that locks the shifter from moving in park fell out of my 2003 F150. I came home, lower the steering column, and finally got it replaced. The truck started and shifted just fine. I then proceeded to reinstall the steering column and trim pieces. Got everything installed and now it won't start. The odometer is blank, the overdrive light on the shifter is on, and it does crank. It simply will not start up. Additionally, the 4x4 light is on and when I roll it back in reverse it does sound like the transfer case is engaged. I tried swapping relays as mentioned elsewhere, but to no avail. What could I be missing? I really need this fixed quick as it is my only transportation. Thanks in advance!
Old Apr 24, 2015 | 06:15 PM
alex1191's Avatar
is your (theft) light blinking when u try to start ,
it's the light on the top right corner I belive
Old Apr 24, 2015 | 07:56 PM
You may have unplugged the PATS transducer, or it fell out of place.
Old Apr 24, 2015 | 08:52 PM
alex1191's Avatar
Yesss there you go that's where I was getting too lol
