Broken Rear Window, Please help!
Old Feb 4, 2015 | 08:46 PM
CCBentz3's Avatar
Hey everyone, I broke out the rear window on my 2001 F-150 today at work. It has a slider but only the window to the left of the slider broke. Do I need to replace the whole back window or can I replace on the left side that is broken? I plan on calling a few junk yards around me because I have been unable to find any left rear windows online, does anyone know a website that I can take a look at if I am able to only replace the left side of the rear window? Thanks for the help.
Old Feb 4, 2015 | 09:45 PM
Hunt4Fun's Avatar
I have never seen one portion of the window for sale. The junk yards are going to be your best bet. If you can find one at a pull-the-part-yourself, you'll save some money. It's not a bad job, just time consuming.
Old Feb 4, 2015 | 10:14 PM
Roadie's Avatar
I don't know about what's available now but I bought a sliding rear window for my 86 F150 from a store like Pep boys back in 1989 or 90 to replace the stock stationary glass. It wasn't that expensive as I remember and it was easy to install. Seemed to be good quality.
Old Feb 4, 2015 | 10:19 PM
Hunt4Fun's Avatar
The 80-96 were easy to replace. All you needed was a rope to pull it in. The 97-03 variety is bolted in from the inside. The window has fixed threaded rods built in. You have to remove a few brass nuts that go all the way around. Plan on getting more sealant or it will leak in the car wash.
Old Feb 5, 2015 | 12:34 PM
Roadie's Avatar
Thanks for the information!
Old Feb 5, 2015 | 08:42 PM
fairlaner's Avatar
If you get a used slider, make sure you get the newer type with the frame around the glass ... the older type will leak on you (the frames crack).
3M Windo-Weld (3/8") works well to seal the window when you install it. The install is not hard, just tedious. There are several good write-ups covering installation on the forum ...
Old type ... usually leak due to internal cracks in the frame
New type ... this is the type to get
Old Feb 7, 2015 | 12:27 AM
2000FordStyle's Avatar
I know what you are going through and yes you have to replace the whole thing as single sides not offered anywhere I checked around. I came out to find this on mine Tuesday and have no clue how it broke as I have a ARE Z series cap on the back and its glass is still fine. Ended up getting another new sliding Ford window put in to replace it with the capped edge as recommended. .
Old Feb 9, 2015 | 09:08 AM
illness95's Avatar
craigslist is great for things like that.. sliders are great for the most part but personally id swap it with a solid window..
Old Feb 10, 2015 | 05:13 PM
H8fulbastard's Avatar
I have a used slider in GC with a tube of the good Pro grade sealant if you are interested and anywhere near upstate SC. I'll take $25 for the window and sealant.
