Upper and lower control arm torque specs
Old Jul 25, 2020 | 10:57 AM
RyanTheNurd's Avatar
Does anybody know the torque specs for installing upper and lower control arms for a 2000 model
Old Jul 25, 2020 | 01:15 PM
Roadie's Avatar
This is what I copied from a digital manual downloaded from this site a long time ago. It was in table form in the manual. The first numbers are ft lbs.
TORQUE SPECIFICATIONS CAUTION: DO NOT allow inner bearing and seal to contact spindle threads during removal. Damage to threads, bearing and seal could result. Application Ft. Lbs. (N.m) Ball Joint Nuts Lower 83-112 (113-153) Upper 57-76 (77-103) Brake Hose Bracket-To-Lower Control Arm Screw 10-13 (13-17) Control Arm Nut Lower 121-148 (164-200) Upper 84-112 (113-153) Lower Shock Absorber Mounting Nut 22-29 (30-40) Stabilizer Bar Bolts/Nuts Bracket Bolt 19-26 (26-35) Link End 15-21 (21-29) Tie Rod End Nut 57-76 (77-103) Upper Shock Absorber Mounting Nut 35-46 (47-63) Wheel Lug Nuts 12 mm 100 (135) 14 mm 150 (204)
