Intermittent display of odometer
Old Jul 30, 2019 | 12:15 AM
jimbo74's Avatar
5 Year Member
My odometer display is intermittent, is this due toa bad bulb, or a cluster, or some type of lcd screen?
Old Jul 30, 2019 | 09:05 AM
Roadie's Avatar
https://www.f150online.com/forums/el...er-repair.html
Old Jul 31, 2019 | 08:31 AM
Fbird's Avatar
btw...unless you have x-ray vision (or a micro-scope) you will NOT see the cracks in the solder. ...take you about 2 hrs complete.
Old Jul 31, 2019 | 10:48 AM
jimbo74's Avatar
5 Year Member
It can't hide from my dvm....
Old Jul 31, 2019 | 09:57 PM
If you are going to take the cluster apart to do it, reflow ALL the pins. Use a low wattage pencil iron.
Old Aug 1, 2019 | 03:36 PM
jimbo74's Avatar
5 Year Member
I wanted to put in a Lightning cluster, but.... noticed it has a boost gauge...
I might toss in some white gauge face and possibly try to change out the bulbs if possible to LEDs?
Old Aug 1, 2019 | 07:15 PM
Any cluster swap will require reprogramming.
Old Aug 1, 2019 | 07:40 PM
jimbo74's Avatar
5 Year Member
What needs to get reprogrammed? Is this a thing where I need to take it to the locksmith, with 2 pats keys? Like $80?
Old Aug 1, 2019 | 08:52 PM
Ford dealer or a shop that has the Ford software. I don't think this can be done with Forscan. The cluster is married with the PCM and PATS.
Old Aug 1, 2019 | 10:02 PM
jimbo74's Avatar
5 Year Member
ok, so what about the bulbs in there? what size are they before I tear it apart and just try to find some that come close? may need to order some, also, is there some tinting on the cluster? some have weird colors on them.
like this:
https://www.ebay.com/itm/Free-Ship-2...0AAOSwz~pZ-3DJ
Old Aug 3, 2019 | 08:32 AM
Fbird's Avatar
can't find what size they are....
Old Aug 3, 2019 | 10:51 PM
jimbo74's Avatar
5 Year Member
Is there a special tint on them that will effect the color of the bulbs I put in?
Also, I don't have a low wattage soldering iron, but my station has a temp adjustment. Can I go off that? It is a hakko fx888d
Old Aug 4, 2019 | 09:36 AM
That soldering station is fine. I just wouldn't use a soldering gun on it.
Old Aug 4, 2019 | 09:38 AM
jimbo74's Avatar
5 Year Member
Should I use it at a lower setting? It can get very hot. I use it on 10g wire....
Old Aug 4, 2019 | 03:35 PM
Lowest setting that will flow the solder.
