Bed swap
Old Dec 5, 2019 | 06:09 AM
etapbird1's Avatar
Bed swap
I have a ‘97 F150 Supercab with an 8’ bed and the floor of the bed has some rot on one side. I found a bed from a ‘99...anyone know of the ‘99 would be a clean swap onto my ‘97? Thanks!
Old Dec 5, 2019 | 10:00 AM
If it's a Supercab with 8' bed, it should swap.
Old Dec 5, 2019 | 11:35 AM
etapbird1's Avatar
thanks! Are you saying if the parts truck is a Supercab like mine it should
work?
Old Dec 5, 2019 | 01:07 PM
jimbo74's Avatar
5 Year Member
If it is the same cab and bed configuration, it should just bolt on with no issues
Old Dec 5, 2019 | 02:24 PM
Right - and I honestly don't know if a 8' bed off a standard cab would work.
Old Dec 6, 2019 | 12:13 AM
etapbird1's Avatar
Thanks, I’ll need to do some more research.
Old Dec 6, 2019 | 06:07 PM
jimbo74's Avatar
5 Year Member
I am curious if your truck is a 2wd? Also, is the possible donor truck the same configuration or different?
Do your's or the donor truck have the oem flares? My truck does, and because of that, there are a lot of little holes in the fender. If it wasn't there would look funky.
Old Dec 6, 2019 | 09:32 PM
I would expect that a regular cab and the extended cab 8' beds are swappable
Old Dec 6, 2019 | 11:21 PM
jimbo74's Avatar
5 Year Member
they most liekly are...
But I asked about the 2wd vs 4wd, because I thought the 4wds only came with a 6.5 in a supercab
