Spindle lift issues
Spindle lift issues
I put a 3in spindle lift on my 97 Ford F-150 2wd awhile back and have realized that when I try to turn my wheels they don’t fully turn and hit on the lower control arm. Would anyone know why this is happening? I bought the spindles from rough country.
Are you running stock rims with bigger/wider tires?, or do you have rims with a positive offset and bigger tires??
I put a 5.5” spindle lift on mine with 37x13.5 tires and 22” rims that have a +12 offset. They were rubbing bad on my lower control arms but I just used 2” wheel spacers and the problem was fixed.
I’d suggest trying a spacer before you cut into anything
