2001 Ford F-150 xlt bolt patterns
no.... unless they are the "multi-bolt pattern" wheels which can be used with the PROPER lug nuts (ie...think NOT FORD LUG NUTS) where you would then be using a "lug-centric" method of wheel centering. FORD (might be dependant on trim level here) Lariat 17" 5 lug aluminum wheels are HUB-CENTRIC and use a 14mm FLAT washered lug nut.
