Cv axle replacement
Old Aug 8, 2019 | 03:07 PM
jimbo74's Avatar
5 Year Member
Cv axle replacement
Might try to replace my cv today. Do I torque it in the air with no weight, some weight on it, or full weight?
Going to go to lowe's and get a craftsmen torque wrench or a lowe's brand. See what they have. Either will be some $ though, as I need to get one that can go up to 250 ft/lbs
Old Aug 8, 2019 | 04:13 PM
Roadie's Avatar
When I replaced my bearing hubs, I bought the Lowes brand Kobalt torque wrench for less than $100. Seems to work okay and on the box it says it has a life time guarantee. Support the lower A arm with a jack or jack stand.
This is the one I bought. Supposedly a year warranty, but on the box, it states lifetime warranty?
https://www.lowes.com/pd/kobalt-1-2-...B&gclsrc=aw.ds
Old Aug 8, 2019 | 04:57 PM
Have you checked Harbor Freight?
Old Aug 8, 2019 | 08:04 PM
jimbo74's Avatar
5 Year Member
I have checked harbor freight, their is quinn and icon that i like. They seem to better then their regular Pittsburg line. I feel lowe's brand or craftsmen would be a little higher quality though, and price is similar
Old Aug 9, 2019 | 12:11 PM
jimbo74's Avatar
5 Year Member
well look @ this, harbor freight or kobalt?
Old Aug 9, 2019 | 03:03 PM
For just one job, see if you can rent/borrow one from a parts store.
Old Aug 9, 2019 | 04:36 PM
jimbo74's Avatar
5 Year Member
It isn't one job though. I am finding I need it more and more. My current wrench is Harbor Freight Pittsburg and only goes to 150 ft/lbs. It's ok I guess, but this Quinn seems quite good.
Old Aug 9, 2019 | 06:10 PM
Roadie's Avatar
I assume the the electronic torque wrenches require a battery?
Old Aug 9, 2019 | 09:25 PM
jimbo74's Avatar
5 Year Member
Yes 2 AA. I have lots of them.
Old Aug 11, 2019 | 09:56 PM
jimbo74's Avatar
5 Year Member
Got my 12mm 12pt socket, and 35mm socket, as well as the quinn torque wrench 12.5-250 lb/ft
Old Aug 12, 2019 | 10:09 AM
Roadie's Avatar
I only buy 6 point sockets now.
Old Aug 13, 2019 | 01:09 AM
jimbo74's Avatar
5 Year Member
you HAVE to have a 12pt 12mm socket for the 6 bolts from axle to diff. The bolt heads are 12 pt.......
Old Aug 13, 2019 | 03:03 PM
jimbo74's Avatar
5 Year Member
One thing I did notice, is the cv doesn't have a hole in it for the castle nut or cotter pin.....
I did observe the nut did have it slightly smashed in though, much like a stover type locknut, and it is torqued to spec.
Old Aug 19, 2019 | 02:40 PM
Fbird's Avatar
what brand axles did you buy? I've NEVER seen a mechanical lock nut on a servicable part before...much less a torque specific application like a hub bearing.....hmm
Old Aug 20, 2019 | 02:13 AM
jimbo74's Avatar
5 Year Member
I thought it was slightly weird at first also..... but I will say, a lot of fwd imports use that style replacement nut
axle is the heavy-duty cardone:
https://www.rockauto.com/en/moreinfo...&jsn=12&jsn=12
