2001 F-150 Hesitation
Ok guys I have replaced the spark plugs in the truck when I bought it, because there was hesitation at the time.After doing the plugs the hesitation stopped until today, it is hesitation only when I push the accelerator.I am wondering if you guys have any clue as to what is the problem or any suggestions??? The truck has around 100k on the clock.
Ok I had a test ran at autozone and it came up with a cylinder 1 misfire, so what should I look for? where is the cylinder 1 plug and coil pack?
Also I ordered my coil packs too.
You have dedicated "Coils", - (508's) single/ 1 per cylinder = CoilOverPlug (COP) System.
"Coil packs" were on the older 4.6L's ~ Pack = In charge of more than one, or a pack of cylinders.
I just ordered a new set of COPs from Global Automotive on eBay and some Motorcraft Denso plugs. When I go to replace these, and use dielectric grease inside the COP boots, is it the inside of the boot that attaches to the bottom of the COP itself where I put the dielectric grease? I want to make sure I only have to do this once! Is there a instructional procedure in the Forums someplace as I have not had a chance to look yet.
Also, I guess it would be good to let the engine warm up to check out the possibility of a leaking heater hose; there's not any indication of a leak but all of my hoses were replaced about 20K miles ago and there may be an issue.
Thanks for all of the knowledge everyone is dispensing to those of us that aren't as knowledgeable!
Did anyone solve there problem with these fixes?
I was towing my boat over the weekend and it started to hesitate around 1500rpm doing 55mph. If I gased it it went away but if I stayed steady on the throttle around 1500rpm it started to jug. I pulled the boat off and it still did the same thing.
Any help would be great. I heard replacing the plugs could become a pain is this true? (with it pulling out of the and stripping)
1) remove power steering bracket
2) disconnect complete EGR system
3) unbolt and carefully lift up fuel rail
Wasn't that hard, just time consuming. Be Patient. Remember to torque down the new plugs
