Lets see the 6 + 3 club
the tires that are on it are 44's the ones in the bed are 40's
I cut one of the 40's pretty bad so i put some old 44's on it that were alittle dry rotted but thought they would get by, about a month and a half later i had a blowout and put the 40's back on. the cut is on the back passanger side tire, still holding up even being offroaded. Ive benn trying to keep it off the interstate but ive had it up to 80 mph.
Dont want to get new tires till after the motor work.
thanks guys
i have recently replaced the ball joint and tie rod ends and the sway bar ends up front as they were badly worn....what else should i look for up from while putting everything on?
[/IMG]
