Plug change now Misses
Hi all, Well with the info on this informative site I changed the plugs w/ oem plugs torqued to 28ft lb and pulled the fuel rail. When I turned on the key I found that two o rings on pass side #3 and #4 injectors had come off. So gas on manifold as you would expect.Now the trucks idles smooth @650 rpms but when taking for test run it has a miss or more? I used dielectric grease on cop Would the spilled fuel damage cop or maybe an injector got some debrisin it? any sugestion would be appreciated Thanks in advance.
Thanks for reply I Checked the plugs torque is ok when you say check the #s what #s This happened yesterday and for fear of a fire i dried the area as best I could and let sit overnight, got new o rings this morning and replaced all tops on passengers side. No more leaks. I dont know how to check for a bad cop
Okay, yea, most likley the coils. I lost a new Motorcraft that way, - that spring connector came apart on the fuel-line at about 55 mph, - hosed down the motor with fuel. - It's been clean ever since. Luckily I used lots of grease or I may not be here to tell you about it lol.
Yea you can try cleaning, like glc posted
I've seen them blow up twice. One of those times, we had to bring the guy to Emergency. - To remove battery casing that lodged in between his knuckles.
Then dip the protruding spring end in a little lacquer thinner to clean any existing grease from the ends. You don't want the grease preventing contact.
Hasn't anyone got a writeup on this besides Matt? -
http://rmftc.com/howtos/sparkplugs/sparkplugs.html
Remember , those coils are suppose to remain loose and ride on a bushing. Otherwise the housing fractures and moisture compromises windings. They must move freely.
