any one have any subs under their back seat?????
Old Sep 12, 2009 | 01:36 PM
lostyone50's Avatar
hey guys does anyone have any subs under their back seat??? well i have 2 12" rockford fosgate p1s and when i turn them up i get this really nasty rattle from under the truck anyone else have the same problem or fixed it ????? any help really appreciated thanks!!!!
Old Sep 12, 2009 | 01:54 PM
abervintageman4's Avatar
mine does that but my subs sit on my back seat, sound deadening fixed my problem
Old Sep 12, 2009 | 03:02 PM
01f1502wd's Avatar
^x2 on the insulation stuff.
and from the bump of it, your going to start to hear things rattlin around. my back window trim on the inside rattles against my window. and it only gets louder as i turn it up.
Old Oct 1, 2009 | 10:04 AM
jasearmy's Avatar
try looking at mtx audio. they make some under the seat subs that still allow you to fold the seats down and use them. my box has two 8" subs and a 400 watt amp and it sounds pretty good.
Old Oct 1, 2009 | 03:53 PM
silver-savage's Avatar
I had a 99 Scab with two 10" JL's firing downward under the back seat. When I first put them in I got this really bad rattle any time I turned it up, I couldn't tell if it was coming from the inside or outside. Come to find out two quarters, a dime, and two pennies got stuck between the carpet and the floorboard. It drove me nuts until I finally found it.
Old Oct 1, 2009 | 10:40 PM
maddoughboy's Avatar
I have two 10s under mine and have never had a rattle but I also don't get to turn it up very much anymore. However the car that I had them in rattled really bad, I was able to tighten some stuff up but never got it to go away.
Old Oct 2, 2009 | 05:35 PM
mccollum_007's Avatar
I have 1 10 under the passenger side backseat and have this same rattle. Can't hear it inside the truck but if you turn it up and get out you can hear it on that side.
Old Oct 2, 2009 | 08:12 PM
It also could be the cab vent between the cab and bed on the drivers side. It used to make a rattle sound on my screw when I turned it up.
