Replace fuel tank?
Replace fuel tank?
Posted this on another site without much reply so I thought I'd try it here:
A few days ago, I parked my F150 on a street facing downhill. After ten minutes I tried to start it up. It started initially but died. I tried cranking it several times but it would not start. About 30 minutes later, I cam back and got it started.
two days later, I changed the fuel filter. After I pulled the old one out, I dumped the remainder of gas from the tank side of the filter into a glass jar. Instead of a clear golden color, it was grayish with stuff floating in it. Almost like sediment. I remember seeing that color the last time I changed the filter as well.
It has started OK since then.
Some background: I bought the truck used two years ago. It's a 2001 Lariat Supercrew 4X4 with 5.4L gasoline engine.
I think I should just replace the tank instead of having someone clean it. But, can I trust anything other than a tank from Ford? How much can I expect to pay for this? I don’t have the time or tolls etc. to do it myself.
