power window
power window
I have a f150 xlt 2002 super cab I have to replace the electric motor for the window how hard is the door to take apart to get to the motor?
The window will go down but will not go up Is their a place on the web site or pictures of how take the door apart?
Thanks in advance Ralph
Here is what happened so far on this I tested the electric window motor with a battery charger the window goes up (passenger side)and down , at each of the power window switches I have 12 volts the ground is good at the(passenger and drivers side) switch I bought a new passenger side power switch I tried that the window still does not go up just down I cannot control the passenger side window from the drivers side so I ordered a new master power window switch I hope that was the problem. the drivers side window operates fine
Any ideas what the problem could be if the master power window switch does not work?
thanks in advance
thanks in advance
