Best price on 2000 5.4 intake manifold
Old Dec 4, 2013 | 12:27 AM
mosinee's Avatar
looking for a 2000 5.4 upper intake manifold with gasket kit?
hope somone purchased one and didnt really need it.
mine is leaking next to the front injector on passeger side
please contact me with price shipped to mosinee 54455
Dave
Old Dec 4, 2013 | 05:28 AM
$170.79 plus shipping from rockauto.com for a Dorman with gasket.
http://www.rockauto.com/catalog/more...104&cc=1362495
Old Dec 9, 2013 | 01:49 PM
03Fx4JD's Avatar
^ That's a good price, considering any shop is going to rape you for $500-$600 for one if you have them install it, plus labor. Which is another $500-$600.
Ask me how I know.
Old Dec 9, 2013 | 05:10 PM
jbrew's Avatar
The best gaskets will be from the dealer unfortunately, but they're not that bad on price.
Reason why, Felpro has year specific gaskets BUT, - they're not specific to Ford spec revisions per model year. In other words, Fords revised gaskets have a improved sealing barrier over the original OEM's , which were not quite right and problematic. The new gaskets are thickened in the right spots/ passenger side.
Old Dec 9, 2013 | 05:19 PM
jbrew's Avatar
Also when you place the new gaskets, make sure the heads are cleaned with lacquer thinner and completely dry. I run a palm sander over the heads first (w/fine SP), then clean the surface. Fill in any surface pits around the water jackets, if you have such. Don't touch the silicon on the gaskets or heads after before gasket placement (needs to be oil free or they can leak).
Tight the manifold in stages, - make sure you have the proper sequence before torque down.
