Service Engine Soon Light
Old Jan 7, 2014 | 07:09 PM
PearlWhiteGT's Avatar
The service engine soon light came on today when I was driving to work on my 2001 F150 4x4 Screw. I didn't notice ant difference in the way the truck was driving. I stopped by the local auto parts store & had them read the codes. 171 & 174 are the codes that came out.
I just did a tune up on it a couple of months ago. Replaced the COP, Spark Plugs, PCV Valve, Fuel Filter & Fuel Pump with all New Motorcraft Parts. Cleaned the MAF Sensor & IAC Valve.
What do you guys recommend checking for the lean codes? I've read that PCV Valve Hose cracks & will cause these codes. Any advice would be great.
Thanks!
Old Jan 7, 2014 | 07:35 PM
projectSHO89's Avatar
Well, go check those parts....
There are already hundreds of posts about that code pair. Think yours is much different?
Old Jan 7, 2014 | 09:19 PM
PCV elbow behind the throttle body is the most common vacuum leak.
Old Jan 8, 2014 | 12:46 AM
Yup, very different...
