ring and pinion swap? need help
i have a 2001 single cab f150 with a 4.2l v6 standard, currently has 3.55 gears and im running 35's whats yalls input on a good ratio to put in it?
(at 60mph im at 1500-1550rpm)
If it were me I wouldnt even bother if I didnt go atleast 4.35 4.10 aint worth the hassle even 4.35 is only a slight difference really. I changed my mustang from 2.90 to 3.79 gears and it made a huge diffence. I also added an overdrive..
http://4lo.com/calc/gearratio.php
Nope, stock tires and 3.55's.
Made a boo boo, I just edited my previous post.
ok i see now i was confused but i get it now, i found a place that labor is $225 for front and rear is $250, and 4wheel parts sell ring and pinion for around 215-225 for front or rear, do you know of a better place to buy parts?
what i ment by asking him what he thought about the rpms was i need input on is 2100 to high if i do a decent amount of high way driving should i go with 4.10s because rpms are lower i just want to get as much input and help i can i want to gain knowledge
